Sat at the side of the road...
  • Rusty
    • 18953
    So was out for a run today and while going through a village at a sedate speed, there was a loud sound like gravel hitting the car and then the engine cutout...
    On inspection, the alternator belt had disintegrated and oddly the car wouldn't start.
    Long and short, looks like the alternator belt has caused the cambelt to jump... have to wait and see when I get it apart but just waiting for a flat bed to get me the 3 miles home now...
  • 4WDrifter
    • Nov 2012
    • 1250
    Bad luck Andy! Hope it's not the worst case scenario. Keep us posted!
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
    • Rusty
      • 18953
      So the belt put a hole in the cambelt cover and then got caught up. The belt slipped about 10 teeth. Gutted.
      The engine did turn over by hand when checking the timing but not really sure where to go from here. I've set the timing again and the engine turns over cleanly. Not sure if there's a chance of things hitting as it's on stock cams, so may have clearance?
      Guess I'll need to put it back together properly. It turned over cleanly with the timing set but I didn't feel much compression. That said, I can't remember if it was like that when I built it...
        All my fingers crossed for you mate
        Re-set timing & see if it will run. If it does, compression test and go from there. If not, head off etc
        • Rusty
          • 18953
          Pics of the belt remains found in the cambelt cover and the pulley.
            Originally posted by Rusty
            So the belt put a hole in the cambelt cover and thengot caught up. The belt slipped about 10 teeth. Gutted. The engine did turn over by hand but not really sure where to go from here. I've set the timing again and the engine turns over cleanly. Not sure if there's a chance of hints hitting as it's on stock cams, so may have clearance?
            The 3B, AAN, ABY and ADU are all interference engines and if you break a cam belt or the timing gets shoved over too far (10 teeth probably qualifies as "too far") the pistons hit at least one cylinder's intake valves, i.e. 2. Sorry to tell you that.
            Hope I am wrong about 10 teeth being too far.
              On inspection, the alternator belt had disintegrated and oddly the car wouldn't start. Long and short, looks like the alternator belt has caused the cambelt to jump
              So based on this photo from the Audi Museum, you're talking the "serpentine" mult-groove belt? On the AAN, we have a true serpentine belt and there are several stories about the "serp" belt failing, getting bits caught up in the cam belt and taking the cam belt out, resulting in at least two bent valves and a head removal repair.
              • SteveH
                • 4460
                Bad news Andy. Hope there's no damage or if there is, it's limited to a couple of bent valves.
                91 Modded 3B
                14 A6 Avant Black Edition
                • diesel des
                  • 3896
                  Balls. That's a nightmare. Good luck.
                  • AndyP
                    • 6049
                    Gutted for you
                    Anyway I'll be back in a minute, I'm off to check my belts!
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      Aaaa sh11t maaan!
                      Sent from my SM-N910F using Tapatalk
                      • jubjub
                        • Nov 2003
                        • 1239
                        Complete ball ache
                          Oh man, sorry to hear that mate
                            • 4754
                            Can't say anymore than has already been said but best of luck with it.
                            • Nace20
                              • Jul 2007
                              • 721
                              • Country: Slovenia
                              holding fist to run normaly
                              S2 limo
