Sat at the side of the road...
  • LHD_Kid
    • May 2006
    • 3696
    #46
    Originally posted by A80Avant
    Ok I have been hearing noises when the engine is cold so need to make sure the tension is correct
    Sent from my SM-P550 using Tapatalk
    If I understand correctly, it was not actually an issue with the cambelt... it was a break of the alternator belt which freakily bounced off the ps bracket and caused the issue with the cambelt jumping...
    To me, it implies that I should check my alternatir belt a bit more often, but the chances of this happening once are slim... but twice....?
    It worries me slightly because I'm sure I run too much tension on my 3B alternator belt as it has to drive a 120A alternator...
      Sorry to hear this mate. Had you covered many miles since the rebuild? Hopefully wont be too costly to put right
        Done 1500 miles or so. Will have to wait and see what the head is going to cost and all the other bits. £750 maybe...
        • 4WDrifter
          • Nov 2012
          • 1251
          #49
          Originally posted by Error404
          I blame Jesus
          Weird sense of humour he has.
          1996 S2 ABY Coupe silver
          2003 S3 8L dolphin grey
          2014 RS4 B8 prism silver
          • PeterS
            • 423
            Originally posted by Rusty
            I cleaned it to check over; it was pretty sooty before
            Plugs are a nice colour so I'm sure it's running properlyish.
            Yes, Alex, it came apart so easily, I'm surprised it stayed together All stainless fasteners, new gaskets and I torqued everything to the factory manual values.
            Err, you do know that stainless fasteners typically have a lower yield strength, right?
            https://www.boltdepot.com/fastener-i...ade-chart.aspx
            Peter S
            1990 ErsatzS2 - track toy
            1991 Coupe Quattro
            1991 Coupe Quattro
            1995 S6 Sedan
            1995 S6 Wagon
              Yes, hence why I've not used them anywhere that is critical
