Right, heard back from gates and as they don't perceive a market in the US, they're not willing to do a batch in the US so I may be speaking to someone in the UK.
RS2 Cambelt
Originally posted by A80Avant View PostIf the kevlar ones are better isn't 41£ a good price? Could we ask them if everything else fails?Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Originally posted by Rusty View PostThey're ABY AAN belts not ADU. I have requested a price for a batch of RS2 belts.Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Attached FilesLast edited by UrS4boy; 7 April 2016, 16:22.RS2'd 93 UrS4 5 spd sedan
That's good to know. From what I understand it seems easier to get a reinforced one than a non reinforced one from the above post by Andy. That's why I suggested the kevlar option. All I'd need is a 150 teeth one and since they are scarce I'm happy to get 2
Originally posted by RichLV View PostI'm sorry to hack, but is it a big difference? What benefits will I gain if, for example, fit 150 teeth belt+rs2 waterpump on my AAN? Just curious.
The AAN has its radiator well at the front with lots of cool air flow impacting it. I have never heard of a non-clogged AAN radiator failing to provide enough cooling power, even with horsepowers well above stock 230 PS, e.g. 380 PS and above. You are perfectly fine continuing to run a 29 tooth AAN water pump and 151 tooth cam belt on your AAN.
Originally posted by rxl View Postmy rs2 had a 151 belt and ran perfectly..
Front of AAN without water pump showing the cam belt tensioner (same one the ABY and ADU use):
I have an ABY belt on my RS2 and I've thrashed the ball's off it with no problems whatsoever and that's what I'll be replacing it with.
I don't see any issue, the gear ratio remains the same.
In theory one pulley could be 100 miles away as long as there's no stretch the cam shaft would rotate at the same speed.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
