Fuel Cell
  • prj
    • Mar 2010
    • 6308
    It is a horrible idea to make the pump switching manual in any application IMO.
    In the even of a crash the pump will keep going and you have a serious risk of the car catching fire and you burning to a crisp inside it.
    This is why the fuel pump is deactivated by the ECU when the engine is not turning!
    It is a safety issue.
    • Dobby84
      • Feb 2011
      • 1169
      If I go down this route I will wire any new pump into the ECU via existing relay.
      • Dobby84
        • Feb 2011
        • 1169
        Can someone give me the flow rates for the standard 3B pump so I can match up an external one?
        My updated plan is to do something like this with the vent pipe going to the filler cap recess with a turn over valve. The +ive feed for the pump will be via new wiring from the original relay and the -ive will be grounded to the chassis locally.
        • diesel des
          • 3896
          Just to confirm you want something like a 100 micron filter before the pump and 10 micron or tighter after. The flow rates for the stock pump were on s2central.
          • Dobby84
            • Feb 2011
            • 1169
            Cheers, I was looking at similar filters and will check s2central now.
