When I bought my RS4 it flagged a fault on VCDS with the Exhaust gas temp sensor on bank 2. The car drives fine but I assume will be losing a few horses as a result. I have tried replacing the board with an S4 Sid one but I either killed it soldering it in or the problem lies In the wiring elsewhere. I regularly get a fault code saying the sensor is short to ground. I can clear it and on start up it re-appears. I am tempted to get a pair which will set me back £400. I have also considered mapping them out, however having spoken to MRC they don't recommend it as they are an important safety feature.
Has anyone got any experience of mapping these out. I'm not that bothered about spending the cash (although it still hurts) but they are a common failure and can get costly over time..anyone got any thoughts? Regards Steven.
