Hey guys.
I've recently came over the helicoil thread repair (yeah, i'm living under a rock) and thought it would be a nice way to fix my stripped cam cover bolts. Right now I have M8 to M6 studs there, but it's not the best way because the nose of the camcover goes under the cam pulley and because the studs are fairly long, it's an annoying hassle.
So the holes have been redrilled and threaded to M8. Could someone tell me which inserts are needed to return it to the M6 and use the same bolts which are used on other cam cover holes?
I couldn't find any inserts in my location, but stumbled upon some on ebay. Are these, for example, good to get (size advice needed)?
http://www.ebay.com/itm/New-12Pcs-Se...zpIBAAfdP4v6Uw
These are the repaired threads and I also happen to have the 7A cover, if that's of any consequence.
