Help with helicoil insert choice
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    Hey guys.
    I've recently came over the helicoil thread repair (yeah, i'm living under a rock) and thought it would be a nice way to fix my stripped cam cover bolts. Right now I have M8 to M6 studs there, but it's not the best way because the nose of the camcover goes under the cam pulley and because the studs are fairly long, it's an annoying hassle.
    So the holes have been redrilled and threaded to M8. Could someone tell me which inserts are needed to return it to the M6 and use the same bolts which are used on other cam cover holes?
    I couldn't find any inserts in my location, but stumbled upon some on ebay. Are these, for example, good to get (size advice needed)?
    http://www.ebay.com/itm/New-12Pcs-Se...zpIBAAfdP4v6Uw
    These are the repaired threads and I also happen to have the 7A cover, if that's of any consequence.
  • liggy
    • Aug 2010
    • 275
    helicoil kits use specific size drill bits and are supplied with a tap which cuts the thread which the insert then screws into. i think (without checking) that an m8 drilled hole will be to big to tap out for your desired m6 bolt. you may be as well tapping it to m8 and fitting an m8 threaded cap screw...
    • Kieron20V
      • Mar 2008
      • 1505
      You'll be hard pressed to find a helicoil that's m8 down to m6. An m6 helicoil kit will come with the appropriate size tap for the external size of the insert. You can't buy one based on the external thread, they don't work like that. You'll have to open the hole out and tap it to the supplied size if you get what I mean.
      Sent from my Nexus 6P using Tapatalk
      1994 URS4 Avant RS2+
      • dm80
        • Apr 2005
        • 812
        M6/M8 Steel, Threaded Inserts TCM6M8SCR3) from Make Ends Meet. Please check out our full range of stock online
        • Rikki Kitto
          • Feb 2010
          • 6276
          threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
          I used these on my exhaust manifold and they are good
          • mac2226
            • Jun 2008
            • 1289
            I've used recoil thread repair kit part no:35068 size m6-1 drill size 6.3mm 1/4 this was on same rocker cover threads circled in red in above picture and 1 wm thread I recently repaired using this kit
