What stroke are you going for? There are 2 SA engines, 2.5 & 2.6 with the same bore but different strokes from my research. Its an effective 1.35mm difference but a difference none the less.
KV NA stroker build
To be honest the trouble with strokers is that somewhere along the line you need to drop £'s on some component or other. Even if you are fortunate enough to stumble over some Oettinger/GTi Engineering stuff it is usually damaged or otherwise irrepairable! Unless VAG actually made a version in a very similiar spec. As you will know VAG favoured an increase in block height on both the diesel and petrol 95.5mmX81mm configs.
Even those SA pistons might have different compression heights as the bore was the same but the stroke differed. If one or other version is based on the 220mm block then the answer is to source all the components from that engine. There does not seem to be a wealth on info on those variants.
What rods were you going to use as some 10V ones have smaller BE journals than the later 10V/20V/diesel etc.Comment
Might be useful if you haven't seen it! Specifically the recipes!Comment
I don't think they changed the BE on the 10V until the later 2.3 engines. The 10V will be smaller by @2mm. It's been a while since I looked at all this. So the KV and 7A have the same C to C? Seem to recall that 10V stuff was less than 144m.Comment
Hi Simon, I sold you the SA 2.5 pistons and rings.
Why don't you use the 7a block as it looks identical to the kv and even has the mounting point for the fuel reg. No need to rebore then. Good luck with your build. Any questions just fire away
Have just finished my 2.6 short deck stroker and it runs sweet. List of what I used:
7a block
7a rods
95.5mm crank
2.5 SA pistons and rings.
Block required grinding of only one web for conrod clearance where sump mounts.
SA pistons skimmed off 1.35mm from the tops and slight machining off the bottoms for crank clearance.
The only difference between our two strokers is I've gone 20v with a 7a cyl head.
Your kv cyl head should fit straight on to the 7a block as I have done this before.
Will try and find some pics.
Have gone turbo as these pistons are perfect with the big dish for lower compression mated with the 20v head. Roughly works out at 9.3:1 same as standard 3b. Added valve cutaways for valve clearance.Comment
