I'm having an issue with my oil pressure gauge. At idle it's okay, stays right at 2 bar, but when I give the car some throttle the needle goes up quickly, before maxing the gauge at around 3000rpm. If I keep the throttle at around 2000rpm the needle in the gauge vibrates up and down around 5 bar.
Could it be the sender that's on it's way out? The engine is newly rebuilt, so there should'nt be any issues there, but the oil pressure sender is used.
