Possible to read out IAT from ECU and use with Zeitronix
Piggybacks on to the IAT sensor monitored by the ECU
Does not interfere with the ECU reading
Configurable display in degrees F or C
Includes peak-hold mode
Remember that the IAT is already a variable resistance device.
I just found the thread with paul and I can see that it has fixed voltage across a variating resistor as you mentioned. So I guess I need to meassure amp instead.
