Dyno Graph Opinions!
  • ADP
    • Mar 2011
    • 200
    • Home: Bulgaria
    Hello Guys,so today i was on dyno sesion and the car make the following numbers:
    Mods are:
    Stock engine
    NM cams-orinal marks align
    380cc Bosch EV6 injectors
    034 adjustable fuel regulator
    red coils -relayed
    044 fuel pump
    duble side intercoolers
    Wagner exhaust manifold-original
    kkk 24-7200 360 trust bearing billet compresor wheel-stock dimension
    NGK8BKR plugs
    stock back box
    Stock air filter
    98 ron standart fuel from petrol station
    0,9 bar Ultimoth gate spring
    300kpa Ultimoth map sensor
    RS2+ Ultimoth chips set
    345 WHP / 385 WNM
    So i think that the NM are less than normal,need profesionla opinions please!
    Many thaks in advance,Atanas!
  • Audi_CQ
    • 940
    • Country: Norway
    How much boost?
    • ADP
      • Mar 2011
      • 200
      • Home: Bulgaria
      its showing 29,4psi, but ican't confirm that is absolute or working pressure. I will make a test with some boostmeter and i will confirm!
      • ADP
        • Mar 2011
        • 200
        • Home: Bulgaria
        YEs the boost is 1,9 bar overboost,and keep 1,5bar till the redline.
        • mike74
          • Apr 2014
          • 615
          Isn't it running a little lean under boost? I thought the optimum was around 11.5-12 but you're over 12 for most of the RPM range?!
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            dont you mean 345 crank hp instead of wheel horse power (whp)
            TWINCHARGED power,zero lag
            AEM W/M injection
            • ADP
              • Mar 2011
              • 200
              • Home: Bulgaria
              No this is 345 Wheel horse power and Wheel NM!!! This is the first and most important requrement when the car was on dyno! Im intrerest what i put on the aspfalt,not on the crank!
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                sorry,i had no seen the billet wheel
                AEM W/M injection
                • Audi_CQ
                  • 940
                  • Country: Norway
                  385wnm is maybe a bit low for 1,9bar boost, but hard to say if you don't have a std car or RS2 to compare with.
                  • ADP
                    • Mar 2011
                    • 200
                    • Home: Bulgaria
                    This is my doubt! 385 WNM are less than what i expect from this boost!!!!Is it possible the stock exhaust to be so restrictive? My car dont have a Cats!
                    • LHD_Kid
                      • May 2006
                      • 3695
                      Stock exhaust with no cats? (Stock S2?)
                      This is your problem...
                      3" downpipe and full exhaust will liberate more power and, more importantly, potentially a lot more torque...
                      • adam g
                        • Feb 2007
                        • 445
                        Look at the units on the graph. You are making 385 lbft not Nm. This equates to 522 Nm. Is that more acceptable [emoji41]
                        Sent from my D5803 using Tapatalk
                        • Jonas_R
                          • 3780
                          • Country: Denmark
                          What is the drivetrain loss calculated at 20%? Then that would 522Nm x 1,2 = 626 crank Nm that is not to bad.
                          Sleeper S2 Avant +450
                          A6 Avant 2.7t Stage 3
                          Audi S2 Coupe RS2'ed
                          • adam g
                            • Feb 2007
                            • 445
                            Considering its a stock bottom end (rods), I wouldn't want any more Nm than that.
                            • Quattronaut
                              • May 2013
                              • 273
                              Adam G is right. Don't mix up NM and LBft; factor is ~1.35. Your torque is fine. Seen as wnm it is indeed very good. Stock is ~170NM/bar boost at crank, your wnm is still a bit higher. To be honest: both numbers seem to be quite high in my eyes.
                              Drivetrain loss is not constant percentage, but a mix with % and a hp or torque number, so on higher power the overall percentage number gets lower. Between 15-20% should hit it.
