Has anyone uprated their hoses to aftermarket silicone ones? If so, who is best to use or avoid? I've seen some 'roose motorsport' ones available for the s2 b4 but wanted some advice, sorry if this has been asked a million times before[emoji51]
There is an argument to go for Roose hoses... actually 2 arguments.
Faster to arrive
Turbo hose is made with a Nomex layer so is likely to be more heat resistant than the Samcos...
Is that nomex layer on all of their hoses? They do look quality compared to ones I've had in the past! And you do pay for what you get as well
Don't think they put Nomex on all the hoses...
The quality is really superb Having both Samco and Roose hoses on my motor, I know which I would use in the future... Roose...
Did you add the stainless steel clips? Well worth it if you didn't.
Flush the engine through with water before and after they're on, to clean out an old rubbish and make sure you use pink coolant.
Worth replacing the pipe at the rear of the block while you're at it. It'll more than likely snap when you take the hose off anyway Replace the thermostat while you're there too, if you can get to it.
Finally, inspect the auxiliary water pump housing (behind the radiator), as mine went brittle and snapped...
Thanks rusty, got the clips with the order [emoji6] engine has had a full service and cambelt done only a few days ago, I'm yet to collect the car, just getting a few new bits for it, at least it'll look nice lol
Have even bought a set of wheels for it!! Can't wait to collect it and my first drive in it, hope all these years of wanting one is more than worth it[emoji12]
