Baffled Sump Vs. Dry Sump.
  • diesel des
    • 3896
    Ok cheers
    • rs2coupe
      • Oct 2004
      • 1782
      • Home: Trinidad and Tobago Current: United States
      Originally posted by Error404
      For fast road and track unnecessary IMHO but if I had the budget I would do it.
      You should also make the full use of the shallower sump packaging and drop the engine and gearbox down in the chassis which will have a very nice impact on the CoG.
      More details Alex please!
      Cheers mis amigos,
      _Anton
      • jsws3
        • Apr 2012
        • 1174
        • speedfr38ky
          • Jul 2014
          • 76
          How often does an Accusump need to be serviced?
          • macof
            • Feb 2008
            • 48
            • Country: Slovakia
            #20
            Originally posted by Audi_CQ
            Drill a hole in the bolt that holds the oil filter housing and weld on a fitting and connect the Accusump there. Works perfect
            hi,
            have you some photos where is Accusupm connected?
