Engine build questions
  • Lee
    • 1512
    All of my dyno runs with my car in various stages of tweaking with the K24 had peak power between 6500 and 6800 rpm.
    Designun Limited....
    • Lee
      • 1512
      I am surprised your friend didn't say anything about swapping MAP sensors if he is knowledgable in car tuning as well as operating a rolling road. It is a brave thing to do!!
      • sla_s2
        • 166
        so, where is the problem? or the problem is bad chip? max boost is 1.4 bar.
        sla s2
        sla
        '91 s2 3b, 305hp, 480 nm.
        www.4plius.com
        • sla_s2
          • 166
          i swapped them myself and asked them to let me on the rollers, for experiment only.
          sla s2
          sla
          www.4plius.com
          • Lee
            • 1512
            So you got 479Nm at 1.4 bar peak manifold pressure on a stock 3B K24 with stock everything else, and not on very high octane fuel? I have to admit if that is true it sounds very strange. It is also the strangest power profile I have seen on any S2 engine, stock or tuned.
            • Mihnea
              • 1288
              #21
              ROTFLMAO. I'm not making any further comments, it's so easy to know what chips people are running just by looking at the amount of torque they have.
              How much boost are you running at 6000 and 7000 RPM? Programmed boost is 1.35 Bar at 6000 and 1.15 Bar at 7000 RPM, 0.35 over what the turbo can do reliably at 6k and 0.25 at 7k...
              Now I don't know if your actual boost is the same as what is programmed in the chip, but IMHO this can't be right. These 2 chips were programmed for 104 RON fuel, K26/27 turbo, larger than RS2 injectors and they weren't meant for street cars... but Digi-tec stole them and decided they would do just fine... but they don't do that fine, especially after hearing from at least 15 people with spun rod bearings and snapped rods...
              www.MRCTuning.com
              info@MRCTuning.com
              Workshop Directions
              • Baldy
                • 469
                • Home: Sikkim Current: British Antarctic Territory
                #22
                mi mates got an AMD tuned S2 aby engined and they manged to squeeze 301.7bhp@5244 rpm from the standard setup
                so what did they do to his car then?
                Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                0-60 4.9
                1/4mile 13.5
                • Mihnea
                  • 1288
                  #23
                  Baldy, look at stock power, is that 261HP that I can read there????
                  www.MRCTuning.com
                  info@MRCTuning.com
                  Workshop Directions
                  • Mihnea
                    • 1288
                    #24
                    Jesus, APNess's car also made 264HP stock and 312 after the magic AMD remap... still felt slower than one of "my" chipped S2s with only 275 claimed HP
                    www.MRCTuning.com
                    info@MRCTuning.com
                    Workshop Directions
                    • Baldy
                      • 469
                      #25
                      yup that is the stock power
                      everything else was standard on it even the exhaust and filter the only thing not stock was the AMD DV but i cant see that makin any difference
                      well i could only just creep away from him b4 my remap
                      0-60 4.9
                      1/4mile 13.5
                      • porkkis
                        • 1994
                        Hehe. One "cheap HP" rollers they have then
                        The more optimistic RR the more happy customers, right?
                        Sla, get some other software asap.
                        • Mihnea
                          • 1288
                          #27
                          I have personally never seen a stock S2 putting out 261HP. IMHO it's dyno or operator error, on purpose or unintended but error regardless. A stock S2 can't have that much power stock, full stop.
                          Mihnea
                          www.MRCTuning.com
                          info@MRCTuning.com
                          Workshop Directions
                          • Baldy
                            • 469
                            #28
                            it doesnt feel as cool as my new map though
                            0-60 4.9
                            1/4mile 13.5
                            • Mihnea
                              • 1288
                              #29
                              Get that IC done and it'll be even better
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
                              • Baldy
                                • 469
                                #30
                                i'm lookin into what size ic i can get in the aux rad position
                                and custom chargecoolers too.
                                i'll get that inlet temp down then that power can go up :mischeif:
                                0-60 4.9
                                1/4mile 13.5
