K-Jetronic -engine will not start
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Hi guys,need some advise with the old Bosch system in Coupe 2.0 16V.
    Car was not running for years,it didn't have a spark and fuel pump wasn't working.I have got spark and fuel going to the fuel distributor but no fuel going to injectors pipes .Looks like distributor is the fault but maybe I'm missing something ,any help Will be appreciated .image.jpg
  • piotr
    • Jul 2012
    • 1470
    [ATTACH]59608[/ATTACH]
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      did you meassure the fuel pressure?
      TWINCHARGED power,zero lag
      AEM W/M injection
      • piotr
        • Jul 2012
        • 1470
        No,I didn't .Just to add some details ,pump wasn't working at all,when I removed it from the tank ,I tapped it few times and it started to run again spitting lots of dirty (almost black) fuel.Now when I loose the bolt feeding Distributor with fuel it looks like its creating good pressure but I don't know if it is enough ?
          What is the engine code ?
          I can look up what pressures should be... K-Jetronic is a mad & wonderful thing - my first Audi and fuel injected car was K-Jetronic - I was baffled for ages with that before I took an interest in learning about such things.
          • piotr
            • Jul 2012
            • 1470
            Engine code is ACE.I was thinking to try my old ABY pump but I think Jetronic system pump different.My first Audi with KV engine did have this system and not many people want to deal with it .
            • Nuvo
              • Nov 2003
              • 3825
              The ACE engine uses KE -Motronic, not K-Jet.
              • stocious
                • Jul 2012
                • 838
                Does the metering head plate move freely?
                1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                  Correct - will try to dig out some basic diagnostics though - supposed to be a good engine.
                  • Nuvo
                    • Nov 2003
                    • 3825
                    JariP posted a copy of the OFRM which can be found here.
                    • piotr
                      • Jul 2012
                      • 1470
                      Sorry my bad -KE Motronic .Yes,metering plate moving free and the needle in the middle of fuel distributor moving as well.Fuel goes all the way to the distributor but nothing from the four injectors pipes.
                      • RichLV
                        • Mar 2015
                        • 872
                        • Country: Latvia
                        Guys in Latvia usually just swap the fuel distributor from another car. No one troubleshoots...
                        • piotr
                          • Jul 2012
                          • 1470
                          Great info,thank you Nuvo
                          • piotr
                            • Jul 2012
                            • 1470
                            Looks like this might be the reason for fuel not going to the injectors .
                            • piotr
                              • Jul 2012
                              • 1470
                              [ATTACH]59681[/ATTACH]
