Audi Coupe 2.6 more power any tips?
  • joonatan96
    • Oct 2015
    • 49
    Hi im looking to get atleast 50hp off from my audi 2.6 ABC any tips how to do it pretty cheaply or hoe to do it at all it feels so lazy whit the 150hp
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    i think for 50hp or more you need to go on a turbo route
    you can choose for a ecu chip-other cams-k&n airfilter and bigger exhaust but i doubt that you wil gain 50hp................
    TWINCHARGED power,zero lag
    AEM W/M injection
    • joonatan96
      • Oct 2015
      • 49
      Any idea where i could get the chip and those other things i already have Pipercross air filter ?
      • RichLV
        • Mar 2015
        • 872
        • Country: Latvia
        As it's N/A, more "mechanical upgrades" are needed. Either you turbocharge it or you can port the head, lighten the valve train, lighten the flywheel. I have done this on my N/A Audi 80 2.0E ABK engine, and it runs much better than before. I've also skimmed the head more than usual, increasing the compression inside cylinders (16 bar in all 4), I'm running higher octane fuel and much more advanced ignition. It runs much better than my UrS4 off-boost.
        • Henkjan
          • 1705
          I assume you want to keep a V6? In that case, swapping the engine for a 30V 2.8 is an option? because like said in the previous posts, getting 50HP more out off a NA engine will require a lot more effort than from a turbo engine.
            For a 2 valve per cylinder car with fast street cams, you're looking at 70-75bhp per litre, so in theory, 190bhp is achieveable with everything working as it should. In reality, the rarity of these engines means that exhaust manifolds, decent inlet manifolds, flowed heads and cams will be hard to find and very expensive, so basically, it's not worth it from a financial standpoint. For fun, maybe it is... I've played with a few 8V golfs and getting over 140bhp takes effort and 150bhp gets more serious still.
            Replacing the engine with a larger capacity 30V unit will be the best route, or even getting a 2.8 setup in there, along with exhaust and inlet but all of that will cost £££ and you may be disappointed
            • Henkjan
              • 1705
              just a stock 2.8 12V will make the care feel more alive than the 2.6, the latter is a real lazy engine.
              • Ian_C
                • Oct 2007
                • 1008
                I was gonna say this - buy a B5 A4 thats being broken and transplant! Quoted 193 bhp, however at the time German cars crossed a tax point at 193 bhp, which is why a whole raft of German motors all quoted 193 bhp. I sold a B6 S4 V8 and bought a house plus a 2.8 Avant to assist with the DIY, the 2.8 felt surprisingly sprightly coming from the S4!
                B5 B6 B7 B9
                • RichLV
                  • Mar 2015
                  • 872
                  • Country: Latvia
                  193 is the 30v. The 12v is 174 hp.
                  • Ian_C
                    • Oct 2007
                    • 1008
                    The whole point of my post - if you are going to go to the effort of transplanting a 2.8, you may as well pick the 2.8 from the B5
                    B5 B6 B7 B9
                    • joonatan96
                      • Oct 2015
                      • 49
                      In ny Case engine change isnt an option.
                      • Thuppu
                        • 4115
                        Supercharging would propably be easier than turbocharging. I have no experience, but I would guess you can double the power with that engine and stock internals without problems. In bothe cases there would be some diy fabricating.
                        I don't know how the stock ecu will accept positive intake pressure, but you could feed the extra fuel with an external controller and injector/s. Or you could use an standalone ecu.
                        • bluequattro
                          • 2960
                          Nitrous
                          If it goes bang replace with another stock engine and do it again
                            Rip it out and fit a more suitable engine.
                            The ABC is a lazy old cruiser, you will sink proper money into making it fast.
                            Throw a 40v V8 at it.
                            • andy10v
                              • 5996
                              Originally posted by bluequattro
                              Nitrous
                              Fit a wet kit and you can have an instant 50bhp. A used wet kit on a switch could be good bang for buck, if you do it "properly" it will be £££.
                              If you want to play with it for fun then Mance's old stuff;
                              You could build the motor, all your standard NA tuning, high compression, cams, headers etc, but its not good value for money.
                              Turbo or supercharger if you have fab skills, but cost wise an engine swap would be the best bang for buck if you can buy A8s cheap where you are.
                              I always half fancied an ebay eaton from a merc/jag with a rising rate FPR and just see what happens with 5psi or so, stick it somewhere like this;
                              Sold ABY-stock
