chip reading
  • vidar skotheim
    • Apr 2005
    • 566
    • Country: Norway
    chip reading
    Anyone have experience with reading chips and and put the BIN file into a program for reading the info ?
    Got lot of different chips , would be nice to learn what more to do then only read/copy them .
  • irishs2
    • Apr 2009
    • 2455
    I have used the GQ-4X programmer with the s2 chips
    As for manipulating them and knowing what to do. That a whole different and long road.
    Eric
    95 S2 Avant under rebuild.
    • vidar skotheim
      • Apr 2005
      • 566
      • Country: Norway
      read and copy no problem . i undearstand it might be lot of work to learn more , buth should be possibel ..
      • irishs2
        • Apr 2009
        • 2455
        Absolutely.
        There is this thread goes into a little more detail.
        Eric
        • andy10v
          • 5996
          If you just want to read them Winols demo will let you do that, but you cant edit/save changes.
          Tuner Pro will work.
          You can also use free hex programmes to compare 2 bins quickly to find sections that are different.
          Understanding what everything is and does is much more difficult.
          There is info in the thread above, also on nefmoto, ecu connections, chip-tuner etc. It is worth google searching for combinations of aan, adu, 3b, audi, motronic, motronic 2.3.2, bin, xdf, prj, motronic etc
          Sold ABY-stock
          • kymi
            • May 2014
            • 107
            You can compare binaries in TunerPro too. And if you have XDF definitions for the binary (or tables defined with example prj's tool) you can search differencies (only) in defined sections. You can also compare at the table or graph view.
            But really, it's much quicker to do a disassembly for the bin and really see what's doing what. Master one bin from one era, you can easily spot same things from other similar bins. Check the thread irishs2 pointed out and feel free to chat with us.
