Hello friends, this bold week to disassemble wastegate and this to me I have found
Discovering wastegate
Tags: None
to share with you my experienceAttached FilesCharles
Audi S2 Coupe ABY 1994
BarcelonaComment
the piece this in badly been no?Attached FilesCharles
BarcelonaComment
And that is everything............ that opinion you?Attached FilesCharles
BarcelonaComment
Carlos,
Thank you for the pictures.
User friendly translation:
Carlos after doing some pressure tests was loosing lots of pressure through the top chamber of the wastegate. He has dismantled it to try and find the weakest link on our old wastegates.
He doesn't like the look of the main "axis" of the wastegate, is it possible that pressure is loose because of a fault of this part (the one in the second to last picture)
Paul, what do you think?
Cheers,
Rafael94' RS2 Coupe TT (Twin Torsen
)Comment
Sorry,
I did not understand him well. In his case, air comes from the "side exit". He says that the valve shape metal piece you see he is holding looks cracked and air escapes between that piece and the housing where the axis piece enters the wastegate, eventually air goes through the side exit.
Can that piece be bought as a spare?
Don't know if I am confusing even more you guys with the translation
But as I don't know the technical terms just have to describe in the best possible way
Cheers94' RS2 Coupe TT (Twin Torsen
)Comment
Complete WG
As said above the only bit that can be bought is the diagphram
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
