New rad/ no aux rad...
  • dan_b
    • Sep 2003
    • 3670
    Well, am now running around with my new rad after my recent severed top hose connector incident. I also took the opportunity to change the thermostat whilst the rad was out. I also a few months ago removed the aux rad as that was a Mr Leaky.
    I wouldn't say that the ambient temperatures we're experiencing in London at the moment (late March) are fantastically warm, but I guess it's warmer than all the previous months when I've been running without the aux rad.
    Basically, with the new rad installed, the car seems to be running a little hotter than it used to. The gauge now routinely sits at 2 notches above 90C, and, even in March, the cooling fan is coming in on the 1st speed when pottering around/ sitting in traffic.
    I've got a 3B and have (malfunctioning again) Aircon installed.
    Is 2 notches above 90 anything to be worried about? When on the move at pace (m-way cruising), it settles on 90. Oil temp and oil pressures are as normal.
    I'm going to keep an eye on this, I'm worried that with summer approaching, is the cooling system going to cope with the higher temperatures? Is this telling me the new rad (from GSF) is less efficient than the old one, or perhaps the new thermostat is opening slightly later than the old? Can that be adjusted?
    I don't want the car overheating that's for sure, but I'm also not entirely keen on either installing a new aux-rad, or removing the Aircon as I want that to work when the heat comes - actually I wanted it on Monday but alas...
  • pastures16
    • 2058
    id get a new aux rad b4 the summer they were put in to overcome the overheating
    94 s2 avant
    aoc member 1116
    • 91_S2
      • 612
      I recently (3 days ago) removed the Aux rad + replaced the leaking Behr original rad with a Nissens rad. My data is that the temps have dropped 1 hash mark. It used to stick exactly 1 mark below 90C - winter and summer. Now it is 2 hash marks below 90C. I'm one happy camper.
      This is just a datum point. But your temps sound high to me.
      • spink
        • 4382
        Thing is, several people have binned the aux rad and the car actually shows it is running cooler(plus the added bonus of a few less kg's over the front end)
        • porkkis
          • 1994
          Don't worry. No overheating will occur. Relax.
          Rich, your multisensor is now more infected by the wind and those readings are not correct. With fully functioning 'stat the engine will not go under 90C after it has first been reached. Really.
          • 91_S2
            • 612
            I find that plausible. But in any case, what is interesting is relative measurement using the same sensors. Assuming more cooling of the sensor itself, I am probably not very much worse off now than with the Aux rad.
            • Henka
              • 585
              • Home: Sweden
              Well... I have to hi-jack this thread. So removing the aux cooler works ok you say (I can't help but wonder why on earth they put it there in the first place!) but I'm still worried. I was thinking of ditching the aux rad and put a better oil cooler in - like a small Setrab, like half-size of the aux cooler but twice the size of the stock oil cooler. Keeping the oil cool should help cool my engine too right?
              I thought Nissens radiatros where just junk... I mean, aren't they dirt-cheap? At least it was to my Jetta...
              • porkkis
                • 1994
                If you have the climate, check channel #6. There is a raw NTP value from the climate sensor. Thermostat temp gives the value ~65. Bigger value means colder engine. This way you can double check. Another way is vagcom that tells you the temperature the ECU sees. Yet another sensor!
                • Markus
                  • 184
                  Channel #51 for you ABY owners. Shows coolant temp in degrees.
                  Markus
                  '94 Kristallsilber-metallic S2 Avant.
                    I've heard nothing but bad things about the Nisens, search for posts on Behr rads and get the part numbers.
                    It will work perfectly with only the main rad, i was skeptical at first but it works well.
                    • Beetie
                      • Oct 2003
                      • 1517
                      [QUOTE=Jamo]I've heard nothing but bad things about the Nisens, search for posts on Behr rads and get the part numbers.[QUOTE]
                      So have i.......
                      Was a '93 3B, Dont ask now tho......
                      • audiman
                        • 4827
                        The aux rad was fitted to the car as it was exported to hotter climates than the UK. And some people even towed with it (WTF)!!
                        I run a high power car and even with no aux rad it runs at the same temps as before maybe even lower. Not one big tuning firm keep the aux rad i place IIRC.
                        Tom C - www.rcmr.co.uk
                        Audi UR Quattro
                        Audi 100 C3 2.0 5 cyl 115ps
                        Audi B5 RS4 645ps 911nm
                        • Beetie
                          • Oct 2003
                          • 1517
                          I might be ripping mine out then.......
                          Oh and Tom whats the 5 stars mean on your description? pm me them as i cant think of a 5 letter appropriate word?!
                          • audiman
                            • 4827
                            LOL, its the word "Forum"
                            Audi UR Quattro
                            • Beetie
                              • Oct 2003
                              • 1517
                              Thats all i could come up with, but thought it might be something abit naughtier!
