Crank pulley bolt torque
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    Hey guys,just to make sure,crank pulley bolt is torqued at 150nm(15kg)+180°?
    Послато са G7-L01 уз помоћ Тапатока
    Come on Marko. You should have the AAN Shop Manual pdf on your computer by now.
    From FredM's timing belt DIY:
    36. Install the crank lock. Torque the crank bolt to 338 ft. lbs (458 Nm)
    with a 3/4" drive torque wrench or 258 ft. lbs (350 Nm) if you are using the
    Audi crank bolt tool.
    • Majorcina
      • Jun 2013
      • 1334
      2 days ago my hard disk die and i lost all data i had the strongest tool i found in my country is 200nm(20kg) max,and a friend pull out from etka where it says 150nm+180°. So just wanted to double check before i tight it
        200Nm + 180 deg is the correct alternative.
        Best of luck. I applied my weight at 0.6m and got about 120-130deg. That's about 650Nm...
        • LHD_Kid
          • May 2006
          • 3696
          You need to eat more pies....
          • Majorcina
            • Jun 2013
            • 1334
            Strenth is not an issue So 20kg+180°
            Thanks guys
            • blackS2
              • Apr 2010
              • 455
              I ordered one of those years ago:
              http://www.ebay.de/itm/1xRahsol-Dreh...sAAOSwYIhWl3SP
              [__]=oooo=[__]
              • sam80quattro
                • Oct 2006
                • 1496
                does anybody have the torque setting for an audi aeb (1.8t) just after my last failure I don't want it coming lose... have an arp bolt fitted now but arp claim 140ftlb which seems weak compared to the 5 cylinder setting above???
