Get yourself an infrared temperature gun & check before & after temp readings at the oil cooler after a hard run. The IR temp guns have come down in price in recent years & are worth a spot in your track tool box. Before you change the oil establish a baseline, oil pressure reading at a certain oil temperature. Compare this reading with a fresh oil change pressure reading at the same temperature. This could tell you that your oil is breaking down when it gets hot. Get a good sample of oil when you drain it & send it off for analysis. Cut the filter open & look for any obvious metal debris from the bearings.
HTH, Chris
HTH, Chris
