Evening Guys,
In the quest to get 1.9 bar from my RS2 setup i am going over everything in my head trying to figure out what could be causing the missing 0.2 bar.
I i have ordered new Knock sensors which should arrive shortly, however in the mean time i'm thinking of other things i could try.
I've just thought that the small hose to my diverter valve is of the ebay silicone type. I had no issues running the normal homefry at 1.5 bar with no jubilee clip holding it in place but wondering with the pressure up slightly to around 1.7 bar is this hose leaking when under pressure? It slips on and off the nipple without too much hassle so wondering could this be loosing pressure when under WOT allowing the DV to open slightly? Perhaps it would pop off the nipple if not tight enough but maybe not.
Does this sound feasible? Or is it common enough to have these hoses fitted without a jubilee clip?
