An electrical person looked at my S2 ABY because it was not starting. He said it was a bad connection on the G40.
He fixed it according to him. One week later it does not start.
Cutting the story short I purchased a complete brand new sensor including bracket from Bosch.
Any advice when replacing the old one and fitting the new.
Should I look at doing anything else while the work is being done?
orsum
orsum
, i.e. the fault could just be with the G40 harness connector which could be replace for a few dollars (say US$10 for arguments sake). Helps if you ask here before you buy.
