4 port boost solenoid
That must be one hell of a daily driverOne of the greatest benefits with the 4-port is that you are not so depeding on the springpressure.
For example. With my S2 I had a tial 60mm valve with this 4-port. I hade a boost range between 0,5-3,0bar. Awesome for a daily driver with 780hp
As you can have such wide boost range you can adjust power on low gears to get the best traction. If your ecu has this option.
Or boost adjusted based on tps for example.
Ofc I use MaxxECU. ;-)
Edit: used 0,5bar spring
Interesting that the 3 port mac valve vents the top side of the wg to open it but pressurizes both sides to close and relies on the spring. The 4 port works the same way to open the wg but vents the bottom side when closing which would be advantageous if you had a weak spring.The ONLY S2 Golf!
10.42@138mph
https://m.youtube.com/watch?v=0wnkkOfFpXgComment
The ONLY S2 Golf!
10.42@138mph
to keep out of surge
