Hello,
I have a great 2.2 KV engine in my Audi 90.
First i had a problem with cold start, it was running on 4 cylinder after i started it up. And sometimes if it was on temperature and you late it stay on his place for like 15 minutes it started really difficult.
Now i have changed:
Sparkplugs,
Sparkplugcables,
Distributor cap,
Rotor,
Fuelfilters,
5 new Bosch injectors.
Now the biggest proper is solved. The coldstart is much better and it runs steadier.
But the day itself from the replacement the hot start was a big problem. It almost wouldn't turn on i needed to give full gas.
Now it is a bit better as then. but the problem stays. Now it starts inmedialletly but i looks like it is running on 4 cylinders at a low rpm 500 but if you give gas or let it be do for 5 seconds it is running allright again. If i turn it off and turn it back on right after it starts perfect.
It was also running a bit high stationary but i cleaned the ISV and it is better now.
Thanks!
Now i have changed:
Sparkplugs,
Sparkplugcables,
Distributor cap,
Rotor,
Fuelfilters,
Thanks!
