hot start issues
Click on the G39 label in this link I provided to you the other day
and learn
There should be a difference if the lambda sensor is working, unless fuelling is being badly affected by another source. I would borrow or purchase a replacement O2 sensor and give that a try.91 Modded 3B
14 A6 Avant Black EditionComment
Great info there.......this link I provided to you the other day
and learn
thanks daveClick on the G39 label in this link I provided to you the other day
and learn
yes i've vagcom but no error displayed for g62 and engine coolant temperature showing ok in meas block
before i've tryed disconnect the two white wires from lambda but i learned that signal is on single black pin. i'll make other testComment
The lambda's can still give a believable signal to the ECU even though the signal itself is incorrect. This wont throw a code unless it goes way off the chart or there's a physical break in a circuit somewhere. If the sensor's never been replaced and mileage is reasonably high then probably prudent to replace it. My one wasn't throwing any codes and had never been replaced at about 140k miles. It had a beard when I pulled it and smoothed the engine out a bit too
Check voltage between O2 sensor signal wire and GND. Should oscillate between ca 0.2 and 0.9 Volt... (0.2 lean, 0.9 rich). Also check for resistance between the white wires (10 ohm(?)) (to verify that the heating element in the O2 sensor is ok). NB! The O2 sensor is a "downstream" sensor so even if a signal from the O2 sensor is "off the chart" we should not automatically rule the O2 sensor faulty...Comment
many thanks Dynasty!Check voltage between O2 sensor signal wire and GND. Should oscillate between ca 0.2 and 0.9 Volt... (0.2 lean, 0.9 rich). Also check for resistance between the white wires (10 ohm(?)) (to verify that the heating element in the O2 sensor is ok). NB! The O2 sensor is a "downstream" sensor so even if a signal from the O2 sensor is "off the chart" we should not automatically rule the O2 sensor faulty...
i've checked both. between white wires of my probe i've ∞ ohm.
signal wire is fixed to 0.48V all the time with engine on. i've started engine from cold and waited as long to heat up, no changes!Comment
