Bosch 044 petrol pump noise after 375 miles
  • gnutz2
    • Aug 2006
    • 928
    The pump pre filter is the first thing that needs checking, if the inlet is clear and the pump still screams then the chances are that the pump is damaged from running cavitated. Bosch pumps have an internal filter at the 18mm threaded inlet, you could visually check this but I'm not sure how you'd be able to clean it.
    Personally I'd swap to a aeromotive 340 because they're almost silent and supply plenty of fuel for an rs2 spec.
    The ONLY S2 Golf!
    10.42@138mph
    • orsum
      • May 2010
      • 1213
      • Home: United Kingdom Current: South Africa
      Lucky for me they have an outlet in South Africa.
      Will first do all the checks to prove what is wrong.
      375 mile and cavitation has damaged a new pump, I hope not.
      • piotr
        • Jul 2012
        • 1470
        I he'd exactly the same problem.Genuine ,brand new Bosch 044 from my friend shop,Fitted as per forum instructions,all ok when first fitted,but next day started to make this irritating buzzing noise like old tired pump(it wasn't as noisy when I was braking hard)I bench tested the pump,with fully charged battery,relay etc. and submerged in fuel-still making the same no acceptable noise.
        My friend replaced the pump for me ,and the other one is not making any noise at all.
        • orsum
          • May 2010
          • 1213
          Thanks guys for advise will now open the tank.
          • orsum
            • May 2010
            • 1213
            #20
            Removing/replacing the petrol pump strainer basket
            S2 Coupe ABY.
            Has anybody removed the strainer basket when fitting an upgraded petrol pump.
            I am concerned that for whatever reason this could be restricting the flow to the petrol pump thus causing cavitation.
            Has anybody removed this strainer and fitted a different/larger strainer?
              #21
              Sorry, has anyone any photos of the stainer ?
              • orsum
                • May 2010
                • 1213
                #22
                will find one tonight
                No 2 in the pic
                  #23
                  No worries re photo as the diagram 'reminds' me of the strainer under discussion.
                  Just wanted to be sure mine was clean. as well as understand which strainer it was.
                  Mine was either new or certainly clear so the high pitched whining sound from mine is not because of a strainer.
                  Irocially yesterday I had a pedestrian came up to me and tell me that I may have a puncture due to the 'hissing' noise (of the pump) from my rear tyre as they stood near by when the car was idling for a minute or two.
                  Thanks again.
                  • orsum
                    • May 2010
                    • 1213
                    #24
                    Last night I took a 10 mile drive when I first started the car it was quite, when I arrived home it was whining not very loud but it was more than I would be happy with.
                    Will do some more tests before I open it up.
                    • igor136
                      • Jun 2014
                      • 363
                      • Country: Croatia
                      #25
                      Dirty fuel filter?
                      1-2-4-5-3
                      • orsum
                        • May 2010
                        • 1213
                        #26
                        New petrol filter fitted the same time as the pump.
                        Will be checked when I do the flow @ pressure test.
                        • popdemonic
                          • Dec 2007
                          • 1304
                          • Country: Thailand
                          #27
                          I had the real whining noise from my 044 pump too.I went for speedflow check valve and the noise was remedy.
                          The whining was much lesser.
                          one of a few I5 from Asia.
                          • A1QSHIP
                            • Aug 2004
                            • 975
                            More information on the check valve please.
                            TIA, Chris
                            "Nulla tenaci invia est via"
                            • orsum
                              • May 2010
                              • 1213
                              #29
                              Check this filter
                              This is a 60 micron pre-filter, also called a fuel sock, for the Bosch Motorsports fuel pumps with an M18x1.5mm threaded inlet. This little gem will allow in-tank mounting of the popular Bosch 044 fuel pump. It comes with an anodized blue finish. Safe for use with all Ethanol based fuels as well as Biodiesel, Methanol, Etc.
                              Check valve
                              • popdemonic
                                • Dec 2007
                                • 1304
                                • Country: Thailand
                                #30
                                TIA, Chris
                                written by Charles Lloyd(lloyd21)
                                When i first ran the 044 pump.The noise was horrible.it was way louder than
                                the Horns.Charles was first running on BMW check valve with a good result on noise reduction off the 044 and Speedflow check valve.my car got lesser whining noise with speedflow checkvalve.
