TFSI coil pack differences
  • AquaS2
    • 705
    Is there any specific type of coil that is a plug and play option for our cars?
    I'm looking to renew mine with possibly 2.5 TFSI coils on a chipped ABY.
    Will these do the job without any modification?
    https://www.ebay.co.uk/itm/331877387316
    Thanks in advance
    F I R E U P T H E Q U A T T R O
    1996 S2 coupe aqua green sold
    1990 MK2 Golf gti 16v oak green sold
    I normally recommend Beru ZSE032, they are a similar price to that, around £25 each
    Let me know if you need a harness
    • AquaS2
      • 705
      Already running one of yours
      Where do you recommend getting the Beru ones?
        Do they fit under a cover Alex? I bought a nice laser cut cover off German eBay but my red coils are holding it up a few mm.
        • vonbeck
          • 2455
          not sure you can put cover back on due to heat, i`ve used the R8 coilpacks with no issues and are about £25 each
          there are a couple of revisions to these as the ones off golf r`s are different ohms
          stock golf/ tsi 3,3 ohms
          5cyl 4.75 ohms
          R8`s 5.31 ohms
            @ Vonbeck.
            Do you know what are the ohms rating for the oem stock coils ?
            Wanted to see which TFSI coils most closely match the original oem factory coils the AAN / ABY came with ?
            Thanks either way.
            • vonbeck
              • 2455
              [QUOTE=macspring;929137]@ Vonbeck.
              Thanks either way.
              Hi sorry I don`t I`m afraid
              I went with the R8 ones last year when I had the car rs2+`d with custom harnesses been absolutely fine
              Also beware of cheap copy's, I got mine from dealers and they were actually cheaper than other places and your hopefully guaranteed to get the correct ones as theres about 3 or 4 different ones with slightly different part numbers
              • AquaS2
                • 705
                So it's better to get R8 ones as opposed to the smaller engine tfsi ones I take it.
                  Originally posted by macspring
                  @ Vonbeck.
                  Thanks either way.
                  It's not the same thing at all as the new ones have the POS built in.
                    No idea mate, sorry
                      No idea mate, sorry
                      Have you got any on a car?
                        I have some in a box very near the car
                        • vonbeck
                          • 2455
                          what i did but dont think the cover will go back on without some spacers and or vents etc
                          • mike74
                            • Apr 2014
                            • 615
                            I was under the impression if you covered the TFSI coils they overheated and failed fairly quickly?
                              Yes they have to be well vented.
