Extended Performance Oil Filter
  • #16
    With the exception of oil volume, the two filters do appear to have the same spec.
    https://catalog.mann-filter.com/EU/e...lter/W%20950~4
    https://catalog.mann-filter.com/EU/e...ter/W%20719~30
    91 Modded 3B
    14 A6 Avant Black Edition
    • #17
      I checked that too, but I couldn't find anything on particle filtration size
      • #18
        I would certainly help to increase the overall oil volume, if nothing more. And it would be a whole lot easier to change with the hex on the end.
        91 Modded 3B
        • #19
          That was my question about Mobil 1™ Extended Performance Oil Filters .... seems that no one has experience with these ones yet ?
          • #20
            Just about to do an oil change so thought I'd try get it right this time as last time i ended up with a bigger filter but not this one, helped with my oil pressure on idle too up by .5 bar
            • #21
              The old website used to list the filtration specs in microns. From memory it was the same as the 719/5 for the 10v motors, the 719/30 had better filtering. Makes sense to me as diesels motors produce a lot of soot in the oil which could potentiallyplug up a filter.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • #22
                the part# are telling the spec (t's a geman company). The W means screw on oil filter. My guess is that the /30 means 30µm pores, and the /4 thus 4µm, but it's just a guess.
                (my dad used to sell Mann filters, if he were still alive he could probably have told from the number what spec the filter is)
                • #23
                  it does say
                  Efficiency rating based on removing particles greater than 30 microns
                  but that could be the standard for an oil filter
