ABY Misfire
  • nesshead6
    • Apr 2009
    • 598
    Originally posted by Nuno_Cristiano
    Hi Pedro,
    I had this problem too in my RS2. If you touch in MAF connector sometimes all ok and other times no ok. You can prove it with VCDS with 2+2 cable and check in channel 1 fuel trim. If all ok trim is 1.00 if not ok ( problem connector/MAF ) this drop to 0.6 if i remember well.
    In my case was a small aluminium wire inside of MAF sensor was broken.
    Hi, did this issue give a fault code? I've also had this sporadic issue for a long time, it gives an 'overboost' fault code.
