Install the chips
  • bcdesigns
    • Apr 2004
    • 193
    • Country: Portugal
    Install the chips
    Sorry open this post,
    Mihnea sent me the the new remap (2 chip), one is fuel and other is boost, they have a stick on with that info...
    But my problem is, how i now where is the Fuel stock chip and the boost stock chip, they have text? I never open the motronic, thats i why i dont know!...
    This weekend i will install them!
    Audi 100 TDI :mischeif:
    MRC remap; Green Injectors; Champion Sparks; Forge DV 006; Samco Intake pipes; K&N filter
    Xenon 6500k; Pillar Boost gauge; Alpine CDA 9835R on Bose with Infinity Sub
    Oettinger 8x18" with GS-D3 225/40ZR18; Bilstein with H&R Springs (-40mm)
    www.autopamplona.com
    www.mrctuning.com
  • JasonS
    • 112
    Gary's site has some nice pictures.. http://www.unicomsystems.co.uk
    You'll need to unsolder the exsiting chips and install sockets for the new ones..
    1996 A6 TDI Quattro Avant, Xenon HIDs, A4 Autodipping rearview.
    Previous: UrS6 with RS2 bits.. <sigh>
    • bcdesigns
      • Apr 2004
      • 193
      • Country: Portugal
      Thank you, but i am a little dummy... in that site they don't say what chips are the boost and the fuel chip, or say???
      Maybe i need to cancel the swap this weekend
      www.mrctuning.com
      • JasonS
        • 112
        The 27C512 chip is fuel/timing and goes on the TOP board
        The 87C257 chip is boost and goes on the bottom
        • alg
          • Apr 2004
          • 1160
          Yup, the fuel chip is the one on the top board, the boost chip is on the bottom board, where the MAP sensor is located as well...
          From the man himself when I asked boost is B is bottom Fuel is F is top I hope
          Alastair
          RS2
          • bcdesigns
            • Apr 2004
            • 193
            • Country: Portugal
            Thank you all, the Mihnea's chip are installed... Now I need to tune the wastegate because the car only do 1,2 bar... dont know how much is the peak of boost!
            www.mrctuning.com
            • JPL
              • Oct 2004
              • 149
              Bruno,
              My S4 runs Mihnea's chipset, peak boost is around 1.4-1.5 bar.
              Graeme.
              94 UrS4 Avant, slowly modding as we go. Now gone replaced with:
              2001 S6 Avant, V8 works for me!
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Have you made sure you don't have any other problems? Before you play with the wastegate. Something else may be causing the lack of boost.
                SS
                • bcdesigns
                  • Apr 2004
                  • 193
                  • Country: Portugal
                  no, i just will make the wastegate do 0,4bar without WGFV, and after i will see whats up...
                  I think the lambda its doing bad readings, we connected it to the machine, and it draw a flat line, i think the lambda have to do a wave...
                  Yes, Mihnea told me that the overboost will be 1,45 (if everything alrigth)... but we forgot to tell me what is the average boost after the over... 1,2???
                  www.mrctuning.com
                  • JPL
                    • Oct 2004
                    • 149
                    Bruno,
                    I had to give the wastegate spring 2 turns in and replace my very old DV for a new S3 one, both were under advice from Mihnea as it was only giving around 1.2 bar peak boost but it was very consistent. Once those were fixed, full 1.4-1.5 bar was available. I think the wastegate adjustment was just incase I had a weak spring, I'm sure it was the S3 DV that gave me full boost as per Mihnea's chip spec.
                    I wouldn't adjust anything without making sure you don't have any other problems first.
                    Also, Mihnea should be the ONLY person to give advice on wastegate settings, etc for use with his chips.
                    Graeme.
                    • bcdesigns
                      • Apr 2004
                      • 193
                      • Country: Portugal
                      Thanks Graeme... I had pm Mihnea but he didnt replied me!
                      I see now that your "sleeper" avant is doing good boost hope mine too soon
                      Another question:
                      I have a Atmo DV, i asked to tunner about this kind of DV in my engine, and told him about of i read in this forum, that atmo dont work fine... And he said that in 1,8T or new ones ok, but in 2,2T works fine without swap the maf of place... I need a good argument to show him!
                      www.mrctuning.com
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        The S3 DV is the one, P/N 06A 145 710N. It only costs about £17 from the stealer, and rarely fails.
                        SS
                        • bcdesigns
                          • Apr 2004
                          • 193
                          • Country: Portugal
                          but somebody could tell me exactly why atmo dont work fine?
                          www.mrctuning.com
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            Because air that the air mass meter has accounted for escapes through an atmospheric DV. It's a bit like having a boost leak.
                            SS
                            • bcdesigns
                              • Apr 2004
                              • 193
                              • Country: Portugal
                              ok, let me see if i undestood...
                              When i release the throttle pedal, the throttle body close (dont let more air enter on IM) and the DV open to dont let the air escape by the turbo, this make the turbo spin always in the same way....
                              But, when the DV open and throw air to the turbo (in the correct way), the air pass again in the turbo and arrive to the TBody that is closed until i floor the pedal again....
                              And if the Throttle body is closed, what is the diference if the air goes outside or inside???? the air dont pass in the TBody if the pedal is released isn't it?? And everything happen after MAS... so, how MAS measure that air??
                              Sorry my doubts, i am confused
                              www.mrctuning.com
