Install the chips
  • Mihnea
    • 1288
    Bruno, sorry for chiming in so late, I've been away and had no email/forums access...
    I'm glad you fitted the chips ok, the boost you have to run is about 1.4 Bar-1.45 max. so adjust the WG spring carefully until you get there....
    Regarding an open DV, the problem is at idle, where the valve is going to be open by vacuum controlling it, plus they make a terrible sound!!!! Also, lots of open DVs happen not to open anymore after a while, watch out for turbo bits getting into your engine if it happens to stay jammed shut while you change gear at WOT and 7000 RPM, someone I know of has had this happen to him a while back, only because of a crap B a y l * y open DV. So stick with a stock (S3)one, it's much better IMHO...
    HTH,
    Mihnea
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • bcdesigns
      • Apr 2004
      • 193
      • Country: Portugal
      Now i understand, yes, the DV is open when Throttle body is release... i see the DV working when i push the TB...
      I have a double piston FMV004 by forge... until now, its fast and always respond! but maybe i will change...
      Mihnea, that boost is on overboost (1,45) or is always 1,45?
      I will buy a new lambda tomorow and remove the cats... and install the new WG, after of that, i will tunned the screw... THANKS MIHNEA, love the car now, very fast response! Hope i dont stop here, new turbo and stuff, and a new remap! but for now THIS ROCK
      Audi 100 TDI :mischeif:
      MRC remap; Green Injectors; Champion Sparks; Forge DV 006; Samco Intake pipes; K&N filter
      Xenon 6500k; Pillar Boost gauge; Alpine CDA 9835R on Bose with Infinity Sub
      Oettinger 8x18" with GS-D3 225/40ZR18; Bilstein with H&R Springs (-40mm)
      www.autopamplona.com
      www.mrctuning.com
      • Mihnea
        • 1288
        Hi Bruno, I'm glad you're happy with the car. You are correct, 1.45 Bar on overboost is right, then it should drop off to 1.3-ish and hold 0.8-0.9 at the redline....
        HTH,
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • porkkis
          • 1994
          Atmo type valve lets out air that has already been measured "in the system" by the MAF. MAF is the king input in our engine management and that's why it's bad. It will run extremely rich when air is let out.
          • audiman
            • 4827
            Maybe my Bailey DV needs a clean out to stop the turbo from chattering then
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
            • steve930
              • Jan 2005
              • 95
              #21
              sorry to hi-jack thread
              tommy have you fitted your clutch yet??????
              i had an air injection blanking plug (exhaust) fall out on redshed2 today, sounds like a lister stationary engine now
              on holiday from S2 ownership
              forget the house bills, spend it on the car :rotflmao:
