Aftermarket crank pulley issues
  • Antsa
    • Nov 2016
    • 611
    Does anyone of you people have aftermarket crank pulley fitted?
    I bought one for my ABY once I read how the old OEM ones have
    cracked pulleys. I was looking for a more rigid pulley to make
    sure it takes the crank bolt 450nm torque. I have the Tommi's
    Billet pulley now. However when fitted the pulley and timing belt
    I had hard time to make belt teeth to fit nicely from pulley
    to the waterpump and finally to the cam pulley. It was roughly
    1/2 teeth off. If left the belt loose the timing was off. Of course
    the solution would be adjustable cam pulley but don't have it so far.
    Of course I thought at first that I messed it all up. But when I took
    the aftermarket pulley off and compared it to the OEM one, the have
    slightly different tooth desing. To make sure that the new pulley was
    causing my issue, I fitted the old pulley back and did another test fit.
    Luckily my old pulley was fine (at least with a visual inspection). Quess
    what? PERFECT FIT! So my question is, does anyone ever had issues w/aftermarket
    pulleys?
    I also noticed two spacers between the pulley and crank. According to this
    there shouldn't be any. When I did my test fit, I noticed that the lower belt
    cover touches the vibration damper/v-belt pulleys. The cover should be fine. My
    question is if there is any harm fitting a spacer or two between the crank and
    the vib damper? I can't figure another way to solve the issue.
  • Thuppu
    • 4115
    Terve! Yes, it's known that Tommis crank pulley is a little bit off. No problem to them who has adjustable cam gears, but some trouble for them who have stock setups. There is no problem using the stock pulley if you have a proper locking tool when torqued down(need to lock the damper not the crank).
    I assume you have an AAN engine? There is two types of AAN dampers, old style without washer/spacer and new style with the washer. And if you don't use the washer the damper will hit the cover just like you notised.
    • Antsa
      • Nov 2016
      • 611
      ABY is what i have Oh, and I have the proper locking tool for the damper!
      • Thuppu
        • 4115
        Aah, you told it in your first comment, didn't register it... About ABY damper I don't know.
        Edit. I think the ABY damper also needs the washer. It's some diamond coated special washer. http://www.s2forum.com/forum/showpos...7&postcount=20
        • Jonas_R
          • 3780
          • Country: Denmark
          OK so tommis Sells a pulley that gives a bad timing? Is that all pulleys? Because then I think I will get another one.
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
          • Antsa
            • Nov 2016
            • 611
            Tommi's pulley has timing issue if you have stock cam pulley. Solvable if you have adjustable one. I think the terrybullwon ones have no issues, they are sold on the parts for sale/trade section on this forum I think.
            • Jonas_R
              • 3780
              • Country: Denmark
              Yeah I just reliased I have a Tommi pulley, not that cool that is has timing issues. I will contect terry and get a one of his instead.
              • Antsa
                • Nov 2016
                • 611
                Deffo not cool. I bought one just in case my OEM one was cracked, but it wasn't.
                • piotr
                  • Jul 2012
                  • 1470
                  • Home: Poland Current: England
                  I have got on from Terry B and it Sims to be spot on
                  • LHD_Kid
                    • May 2006
                    • 3695
                    It is spot on... beautifully made, perfect fit...
                    • Antsa
                      • Nov 2016
                      • 611
                      If I only had known it before I bought the Tommi's one
                      • Thuppu
                        • 4115
                        You can propably sell it quite easy, as it's not a problem if using adjustable gears.
                        • RichLV
                          • Mar 2015
                          • 872
                          • Country: Latvia
                          Have TerryB's pulley as well on stock setup. Well spent money.
                          • Antsa
                            • Nov 2016
                            • 611
                            I think I'm going to keep it as the engine will see some mods in the future
                            • sailaz
                              • Oct 2009
                              • 647
                              • Country: United Nations
                              Good business by Tommi - you buy pulley and then realize that you have to buy from him adjustable cam gear to use that pulley
                              But then naturally comes next question: is this cam gear has no issues
