So continuing with the shakedown of my S2 Coupe ABY. Yesterday something strange happened.
Did about 100km and the car was fine. Car was stopped for about one hour to have the wheel alignment done.
Started no problem, pulled away slowly, stopped at a junction, waiting to pull away from a junction, as I was pulling away I put my foot down the car got to about 2500rpm and it just felt like there was a big jerk total loss of power. Took my foot of the accelerator and then gently pressed the accelerator a small way down the car was not accelerating more like cruising normal.
So under light acceleration and the car ran smooth.
Took the car to and Audi dealer and asked for the Tech to go for a drive. The car did the same. Tech said typical coil pack issue. Replace coil packs and problem should go away.
So I left Audi thinking no problem have a conversion kit at home to suit the R8 coilpack upgrade. I left Audi and did about 30KM stopped at a friends to collect a couple of mono blocks for my sound system and had a coffee.
About one hour later I started the car drove off and hey presto no more problems running smooth.
All the way home no problems on the drive home I pushed the car to 240kph it ran very good.
Its still running good.
Anybody wish to put a possible cause to what happened.
No codes taken Audi said they had a problem with getting the right connector!!!
