Alternative crank pulley tightening method
  • urq20v
    • Sep 2003
    • 218
    I have had the head off my RR urquattro to fit a new head gasket and cambelt and am now ready to torque up the crank pulley/harmonic balancer bolt. 450nm of torque is way beyond the maximum of my torque wrench and I don't have access to a larger one. I could fabricate a torque extender but I think my torque wrench would break in this situation.
    As an alternative method of torquing up the bolt I have read that Audi issued a bulletin 10/93 for the ABY/AAN stating that 150nm + 180 degrees was acceptable. Since the RR and ABY/AAN bolt is the same part number, would this method be OK for the RR? My torque wrench will do 150nm and I have a 3/4 drive socket set and long bar to turn the extra 180 degrees. I also read that this is a common method used by quite a few other manufacturers.
    Has anyone else used 150nm + 180* on an RR or 3B?
    Any advice would be greatly appreciated.
    Rex
  • AndyP
    • 6049
    I've tried this before but never managed to get to 180°, despite a 3/4" breaker bar and a long extension! Never had it come loose either though
    • merlin's S4
      • Jan 2005
      • 1539
      I used that method on my AAN. No problems so far.
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        Used loctite and a 1" impact tool
        Its not going Anywere ��
        • domas
          • Oct 2014
          • 307
          • Country: Lithuania
          Using impacts can result in shattered crank gears.
          • LHD_Kid
            • May 2006
            • 3695
            Did you use an impact gun to tighten it????
            We know it isn't good practice to use a gun as this is what likely damages the key on the pulley...
            • s2dk
              • Jul 2016
              • 507
              • Country: Denmark
              Im allso using terrys cranck sprocket
              Never had Any problems with it
              Or with usining inpact guns to tighten Them
              • Bowie69
                • Nov 2013
                • 2675
                If using chef's pulley, then it is billet, whereas the OE ones are cast, then machined. Billet won't fracture, unlike cast in that situation, but I would still get it really well seated before attacking it with a gun.
                I made a crank locking tool, and have a loooong 3/4" drive bar, know my bodyweight and where to place it on the bar to get the right torque
                  450nm for me - my 75kg body weight on a 600mm breaker bar - job done
                  • Bowie69
                    • Nov 2013
                    • 2675
                    If you wanted to get all technical about it, get yourself a spring balance, and some strong arm muscles
                    • LHD_Kid
                      • May 2006
                      • 3695
                      75kg... and I'm dating a 23 yr old supermodel...
                      • domas
                        • Oct 2014
                        • 307
                        am i plain wrong or you are supposed to use 6 meter long breaker bar in this case to achieve needed torque?
                        600mm is 0.6 of a meter...
                        • LHD_Kid
                          • May 2006
                          • 3695
                          τ = F x r
                          Symbols
                          τ = Torque
                          F = Force
                          r = Lever Arm Length
                          75kg @ 60cm = 441.29925 Nm
                          • domas
                            • Oct 2014
                            • 307
                            Originally posted by LHD_Kid
                            τ = F x r
                            Symbols
                            τ = Torque
                            F = Force
                            I agree with everything apart from the fact that you use centimeters where you are supposed to use meters.
                            wait what.
                            it is more like 75*~10*0.6M
                            **** never been so wrong in my life.
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Weird, was sure I wrote a reply to this....
                              1Kg = 9.8N, so...
                              75Kg * 9.8 * 0.6m = 441Nm.
