Spluttering
  • John.
    • 2615
    Originally posted by newsh
    If the diaphragm in the FPR ruptures, fuel flows straight through the vac tube into the inlet manifold
    Ah Yes ok. I was thinking along the lines of spring breaking causing drop in pressure as more fuel being returned to tank.
    • DEREKCO
      • Feb 2009
      • 435
      Spluttering
      Well after looking at previous posts and especially posts from urs4boy I am 100 % certain its lambda the evidence is to overwhelming will post results tomorrow
      • DEREKCO
        • Feb 2009
        • 435
        Spluttering
        Well after fitting the new lambda probe no change car starts first time it tick's over sweet for about 2 mins the revs drop till it stalls ,try giving it some throttle no joy it virtually strangles the engine will give it another scan after tea
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          0537 VAG1551/2 Fault Code Number
          Oxygen Sensor Control Limit exceeded,
          fuel pressure too low or too high, intake or exhaust leak, defective ignition system component, intake air leak after air mass sensor, O2 sensor is faulty
          00525 VAG1551/2 Fault Code Number
          Oxygen Sensor (G39)
          Sensor Wiring or Sensor defective Heat resistor in sensor defective, Signal wiring shorted to ground, Fuel tank empty, Ignition system component failure, air leak at mass air flow sensor, air leak in exhaust pipe before catalyst, poor ECU ground wire connection at intake manifold.
          Symptom: Emissions not within specifications, increased fuel consumption, rich exhaust, spark plug fouling,
          Carbon Monoxide (CO) percentage above 3%,
          00513 VAG1551/2 Fault Code Number
          RPM sensor (G28)
          Open or short circuit, sensor malfunction
          Defective sensor & cables, metal fragments on flywheel teeth
          Symptom: Engine will not start, misfires, may stop running
          After changing lambda probe... scan for codes. i wouldint say that rpm sensor is fine... i would take out and clean from the metal fragments on the tip.
            Have a look at coolant temp in Vagcom, see if it agrees with reality.
            • DEREKCO
              • Feb 2009
              • 435
              Spluttering
              New code has flashed up 00553 MAF sensor
