Turbo boost.......problems
  • mike74
    • Apr 2014
    • 615
    Sounds very promising, good on you for persevering for so long
      How did you cure it?
      • wastegates
        • Dec 2004
        • 351
        • Country: Spain
        #78
        Hi friends, first to thank all those who have been giving me advice to review the S2, have been a pile of things that have been happening while we were dismantling ............... solved a Fault and another came out as you can check in the post.
        Before I said that I would put the photo of the last fault after loosening the catalysts this morning to check that they were not plugged (I have 2 sets of catalysts) .................. .............. desperate and for the very last time after having solved countless air leaks, I have again made a pressure test and ............. Again another leak ........................ but how is it possible? If I've done at least 10 pressure tests in the last few weeks.
        Well again yet, and by the end it works quite well, today I have seen 1.45 bar
        In the photo you see the Diverter 710 N, I usually have the Forge installed, but I already suspect everything and I have been changing it to check the name of it.
        Charles
        Audi S2 Coupe ABY 1994
        Barcelona
        • wastegates
          • Dec 2004
          • 351
          • Country: Spain
          #79
          Thanks to everyone, I hope this post serves someone to solve problems.
          Charles
          Barcelona
