Hello
Does vems have a feature where it pulls the timing or something If the iats is High fx If driven hard and Then idles for a time so the iats rise to like 70 degreese?
The problem with my car is that If sat for a while in idle the. I wont boost before 6000 rpm and the boost Will only hot 1.3@6000 ish instread of 1.6 @4000
Of the car is driven for 2 km and the iats are Dow. To normal 0-20 degreese Then its fine and running great..
Or Could it be a mechanical problem? Maybe a bov that cant handle the idle heat?
and it stilled runned great.. nex step will be to se ign when wot and high mat
