My RS2 needs new timing belt. Only able to find a kit for normal B4 at 034 motorsports. I wonder if RS uses the same kit. If not, where can I find a complete kit for sale. Thanks
RS2 Timing Belt same as S2 ?
they are not the same, you can only use the s2 belt if you change to an s2 water pump pulley at the same time.
try quattro corner in uk for the correct rs2 belt -
Rs2 Belt is a little bit shorter because of the smaler Diameter of the waterpump pulley[__]=oooo=[__]Comment
I was wondering this too as the belts are 1 tooth different I think. I assume the reason is that the tensioner adjustment is needed, but haven't been able to get a definitive answer to it?Greg
