RS2 Timing Belt same as S2 ?
  • wowow
    • 123
    • Country: Hong Kong
    My RS2 needs new timing belt. Only able to find a kit for normal B4 at 034 motorsports. I wonder if RS uses the same kit. If not, where can I find a complete kit for sale. Thanks
    ________________
    RS2-95
  • nicksonmsport
    • Mar 2014
    • 380
    they are not the same, you can only use the s2 belt if you change to an s2 water pump pulley at the same time.
    try quattro corner in uk for the correct rs2 belt
    • michaels2s
      • Nov 2012
      • 87
      Rs2 Belt is a little bit shorter because of the smaler Diameter of the waterpump pulley
      [__]=oooo=[__]
      • sailaz
        • Oct 2009
        • 647
        • Country: United Nations
        .... http://www.s2forum.com/forum/showthr...S2+timing+belt
        • treebirch
          • May 2014
          • 244
          You can get an RS2 timing belt from Audi Tradition, when I bought my last one it had no Audi branding on it at all, only Gates! Perhaps Gates can supply you direct?
          • wowow
            • 123
            thanks guys
            ________________
            RS2-95
            • mac2226
              • Jun 2008
              • 1289
              Quattro corner in uk last time I got one £50
                I was wondering this too as the belts are 1 tooth different I think. I assume the reason is that the tensioner adjustment is needed, but haven't been able to get a definitive answer to it?
