Audi S2 91 3b - over fuel/stalling - HELP :)
  • _Denner_
    • Jul 2009
    • 15
    • Country: Denmark
    Hi
    I dont know where to write and ask about my s2 3b,
    Dennis
    Denmark
  • s2driveruk
    • 12696
    go ahead...whats the issue
    1992 3b S2 Coupe
    • _Denner_
      • Jul 2009
      • 15
      • Country: Denmark
      I have a Audi s2 3b 1991, i have just had the engine & transmission out
      and then in again, and now it gets too much fuel, and when i speed up the engine and let i go down to idle, the engine stops, and if i keep it at ex. 3000 rpm it misfires, i have put in new spark plugs, changed the coolent temp sensor, changed intake air temp sensor, the timing is correct, and the injectors has been cleaned and testet by a firm.
      The engine ran just fine before i took it out, i took it out to renovate the engine and change transmission and clutch.
      Have i put something wrong back together or....
      I hope that some of you may have some suggestions to what the
      problem could be..
      Dennis
      Denmark
      • s2driveruk
        • 12696
        hold tight, plenty of tech advice coming I'm sure, i've changed the title of the thread to help it get seen
        1992 3b S2 Coupe
        • mike74
          • Apr 2014
          • 615
          I'd do a boost leak test first and foremost. Sounds like its sprung a leak somewhere
          • mike74
            • Apr 2014
            • 615
            oh, and any fault codes stored?
            • _Denner_
              • Jul 2009
              • 15
              • Country: Denmark
              s2driveruk perfect thanks
              mike74 nope no fault codes stored
              • mcandmar
                • Apr 2004
                • 5118
                Are you sure your firing order is right, i.e. have you got the spark plug leads the right way around?
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                • _Denner_
                  • Jul 2009
                  • 15
                  • Country: Denmark
                  mcandmar : yes its not that kind of missfire
                  my mind is on the injectors , maybe they could not handle the detergent cleaned them with, and the reason i got them cleaned was becuse of to old fuel so it would not start, but it startet up after they where cleaned
                  • _Denner_
                    • Jul 2009
                    • 15
                    • Country: Denmark
                    by the way sorry for my poor English, i try not to use google translate too much
                      Check the pipes of the PCV system are correctly connected. If you swap two pipes over you can get all sorts of problems.
                      And yes, do a boost leak test.
                      And check the Diverter valve diaphragm is not split
                      • _Denner_
                        • Jul 2009
                        • 15
                        • Country: Denmark
                        newsh : Thanks i will try that
                        • vr6peter
                          • Dec 2003
                          • 223
                          • Country: Austria
                          Hi.
                          When you overfuel try a pressure test at the fuel rail.
                          May be you need a new fuel pressure regulator.
                          Peter
                          • _Denner_
                            • Jul 2009
                            • 15
                            • Country: Denmark
                            vr6peter : fuel press is just about 3 bar
