NEED HELP ASAP. 1990 Coupe Quattro 7A
  • Grillage
    • Apr 2012
    • 156
    Broken flywheel pin?
    Can you check codes?
    1994 Cabriolet - 5 speed
    1995 90
    2011 A4 Avant
    1990 CQ - V8 (sold)
    • Kevin_kiely
      • Mar 2017
      • 24
      http://20v.org/fault.htm
      i do not have a test light but i will see if i can find one, how do i see if its a broken flywheel pin?
      • Kevin_kiely
        • Mar 2017
        • 24
        Originally posted by chezz
        Broken crank pulley keyway?
        the crank pulley on the front of the motor?
          Follow these instructions I posted earlier to see if the timing is correct.
          I've added some detail, if you still don't understand ask questions.
          Check the timing, 3B
          Set the Flywheel on zero mark (seen through small window in bell housing)
          Dizzy rotor mark should be aligned with mark on casing. (You may have to turn the engine another whole revolution as the dizzy moves at half the speed of the crank)
          If the dizzy still goes round but these marks don't line up then it's time to take off the cam cover and check the alignment of the cams.
          There's pics here
          • Bowie69
            • Nov 2013
            • 2675
            The toothed pulley behind the large pulley has a key cast into it, these can shear if timing belts are carried out with a mahoosive rattle gun rather than the proper locking tool.
            It only needs to slip a few degrees to stop it from running, I have had this, twice, when someone in the past did the belt....
