My 3b coupe has developed a starting problem when the car is hot or when restarting.
I have a sigma alarm on it ,so you have to press the fob to get the ignition to light up.
When first starting the car from cold it starts every time, even starting ,and restarting several times no problem.
After a run however press the fob and the ignition lights come on as usual ,but when you turn the key the starter wont engage.
After repeated attempts the car will start.
Any help or advise would be much appreciated.
