Cam position sensor
  • Harris1
    • Jan 2015
    • 18
    Cam position sensor
    Help please does anyone know how many ohms the cam position sensor should be
    (ABY)
  • johne
    • Apr 2007
    • 1404
    It's not an "ohms" sensor, it's a Hall effect sensor so knowing it's resistance doesn't really help. If you're looking for help troubleshooting the sensor, there's lots of posts on here.
    John
    • Harris1
      • Jan 2015
      • 18
      Thank you I will have a search
      I parked the car up 2 months ago and all was well then yesterday I went to start it and was flat I then replaced the battery but still will not start turns over fine
      Fuel pumps relay is ok
      Fuel pump ok
      Suspect injectors ???
      • johne
        • Apr 2007
        • 1404
        Injectors are bullet proof unless a mouse has eaten the wiring and anyway if one's failed you've still got 4 left to start the car
        John
        • Harris1
          • Jan 2015
          • 18
          Sorry
          What I meant was when I say injectors is the Ecu is not grounding / earthing the injectors and I believe the the ecu picks the injector sequence from the G4 and the g40 sensors
          • LHD_Kid
            • May 2006
            • 3695
            Originally posted by Harris1
            Sorry
            Rather than just "guessing", have a read through This
            • piotr
              • Jul 2012
              • 1470
              • Home: Poland Current: England
              Can you read codes?
              • Harris1
                • Jan 2015
                • 18
                Will get the diagnostic kit from work next week and have a look going to have another play after F1
                  G40 Cam Shaft Position Sensor Info
                  G40 Cam Shaft Position Sensor Info:
