Smell in the car
    Smell in the car
    No I didn't have a curry last night
    I'm getting a smell of breather fumes inside the car, I think, I'm pretty sure its not exhaust .. Is it possible the pcv system is leaking into the car? how does the pipe to the fuel tank route? I'm wondering if boost pressure is pumping fumes into the car, its not too strong but still noticable when I drive reasonably hard.
    I have replaced just about the whole breather system quite recently.
      fuel lines run under the car. check around by air intake for heater on passenger side there may be some fumes gettin thru around there.
      • 91_S2
        • 612
        3 Lines run parallel from the gas tank to the motor compartment. One is the a vent for the gas tank and leads to the charcoal canister. The two others are the gas lines. All three of my lines are corroded as hell. Very local corrosion where it came in contact the Alu heat sheild. I suspect a galvanic element was created between the two metals. The lines are NOT cheap. 1900 kr = £146 for the 2 gas lines.
        • zlobo
          • 967
          check the maintinece cap over the fuelpump.. .some time tne rubure gasket leaks..
          ABT C5 Lord Of The Rings
          2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
          2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
          2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
          kostic.nu
          • mcandmar
            • Apr 2004
            • 5118
            When i had a cracked exhaust manifold the fumes allways found a way into the car even with the heater switched off. Might be a leak somewhere on your downpipe....
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • Fat Audi 80
              • 10547
              Personally I would suspect the Exhaust system has a small leak somewhere....
              The Perfectionist
                Ok Yes, I'll be looking at the exhaust system pretty carefully then, its not fuel But i wondered if the carbon canister line was getting boost pressure..
                I have a new plastic top to fit to the dipstick tube too as that is broken and repaired with a piece of rubber pipe.
                • Henka
                  • 585
                  • Home: Sweden
                  Check the fuel lines. Leaky worn fuel lines can cost your life...
                    Its deff not the smell of fuel, although its a good idea to check the fuel lines.. Its more like a smell of hot oil, like if the breather is disconnected from the crankcase, except it isn't.
                    I have the usual RS2 Turbo symptoms, puff of smoke from the exhaust every now and then which is quite smelly. Its a bit like that but inside the car, driving along with the fan off and windows closed.
                    • Henka
                      • 585
                      • Home: Sweden
                      Ok well then...
                      -Check leaky PAS pump --> oil on engine block, smells like hot oil, not scorched oil
                      -Check leaky valve cover --> oil on EM (scorched) or OIL on engine block (hot)
                      -Check for leaks around timing cover (around cambelt and such)
