Testing the coilpacks and all of a sudden we lost power to the coilpacks and injectors and ECU
All the auxillary lights etc work,and we've traced the wiring / fuses back, ignition switch etc all seems to work. We've brought power from the ignition switch up to the base of the coilpacks but still wouldn't start??
Any obvious fuses that might have blown for some reason??
Any help appreciated as I'm stranded at the garage with the mechanic who's trying his best at 820pm!!
Karl
Oz
Karl
Oz
It is now 11pm here, we have spent over 6 hours trying to fix it to no avail. To sum up, we have power to and from the ignition. All interior lights etc work. I have no power to ECU, injectors or coilpacks. Fuel pump works, fuel pump relay works when relay closed manually. All fuses that I could find have been checked. This happened so suddenly, whilst testing the coilpacks through a proper tester. We found 3 weak coilpacks out of 5
Six and a half bloody hours and we couldn't even spot it
Very much appreciated
