Hall sender/camshaft position sensor?
  • Crawford_S2
    • 1555
    I had an annoying experience today and wondered if it sounded familiar to anyone.
    My ABY coupe has been running perfectly for ages now so i am due a week or two on the bus I had gone out this evening to pick up my daughter and when i got back in about half an hour later it started fine but on the way up the road it was only boosting to the 'safe' limiter. I have no gauge at the moment but could tell as it drove like a non turbo. I pulled over and turned off the engine but then it would not restart for about ten minutes.
    I recalled this happening once before a year or two ago and it hasn't done it since but this time it has left the ECU in 'limp home mode' with only low boost.
    Will pull the fault codes tomorrow but looking through the threads it sounds like the hall sensor. is this the one behind the cam pulley? Any idea on price and BTDT's on its replacement. I take it the cambelt and whole front needs taking off to replace it Anyone got a part number?
    Ragusa Coupe gone!
  • Crawford_S2
    • 1555
    Pulled the codes today and got it running as it should. Code was hall sender and have ordered the camshaft one part no. 034 905 161 from VAG parts. Fingers crossed it works till then Still looks a bit of a bar steward to change though, anyone done it
    Ragusa Coupe gone!
      If its the hall sender it is more than likely the one on your bell housing.
      • Crawford_S2
        • 1555
        But i replaced that one not long after i got the car and i unplugged the top one and got the same fault codes appear after clearing. I know the codes are likely to be the same for them both but working on the asumption the bell housing one is newer so it should be ok i have ordered the other one.
        Ragusa Coupe gone!
          thats cool. Seems like a reasonable assumption
          • Crawford_S2
            • 1555
            You say that but it is an audi S2 so its probably going to need a new ECU by the time i've finished
            Ragusa Coupe gone!
            • Crawford_S2
              • 1555
              Doh!! ****** thing broke again whilst doing the school run and refused to start for 45 minutes then started and drove perfect!!!????? The journey was 15 mins tops then i stopped for 5-10 minutes, got in and nothing. It turns over but won't start then suddenly it does WTF is going on!!
              Hope this new sensor that is coming tuesday does the job or i am stumped.
              Ragusa Coupe gone!
                might sound like a non technical check but have you checked the contacts on the hall sensor connector that you have already replaced are in contact properly and clean?
                • Crawford_S2
                  • 1555
                  Yeah gave all the connectors a wiggle and a squirt with contact cleaner but didn't seem to do 'out'. Even tried the 'water down the cam cover' thing much to my mechanic mates amusement but no effect. Unbelievable how much of a PITA these S2's are when they go wrong!!!
                  Ragusa Coupe gone!
                  • Crawford_S2
                    • 1555
                    Right this job is officially a right bar steward The whole front needs to come off to get to this firkin sensor
                    Now i have to take off the cambelt and pulley
                    And heres the little fecker here
                    Can't believe its such a nightmare to change
                    Worse still i did the cambelt and waterpump 5000 miles ago and could have easily done it then .
                    Ragusa Coupe gone!
                    • blown_vr6
                      • Apr 2005
                      • 406
                      Crawford - sell that piece of 5hite and buy a Golf ffs
                      'If you ain't broke it you ain't trying hard enough'
                      Oh sh*t i broke it
                      94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
                        Get your st*nking Golf attitude of to your own forum!
                        That looks a right PITA, i'd be a bit peeved if you only recently changed the cambelt!
                        • Crawford_S2
                          • 1555
                          Yes sossage you dirty polish muddy fumpster, get back to modifying your front wheel drive sos mobile If you mod it a bit more you might even keep up with my standard S2
                          BTW Know pete of old and he ain't a ****, just sounds like one
                          Ragusa Coupe gone!
                          • rotoryboy
                            • May 2004
                            • 3281
                            Easy guys, has there been a special on handbags or something
                            Mark
                            Race Clio RS197
                            S2 Coupe ABY (Green) - RIP
                            S2 Coupe ABY (Blue) - Sold
                              It's nearly the end of the footbal season, got to find something else to b*tch about!
                              Has changing the hall sensor fixed the problem?
