Help identifying what turbo i have? Hohenester 310 kit
  • Jonas_R
    • 3780
    • Country: Denmark
    Well,
    Iam sitting here reading my invoice from Hohehenster. The previouse owner got it tuned and renovated there for 6000£.
    I has a "Ausspuffkrümmer s2 rs spez" which should be a hohenester RS2 exhoust manifold.
    However it also says this, should be the turbo:
    K 26-2672 GGC 6.92 mit LG wassergeküh
    Well wassergeküh=water cooled.
    But does this mean i have a RS2 hybrid turbo on? this would be K26 hotside, and K24 cold side right?
    Now assumning i have an RS hohenester EM and Hohenester RS2 Hybrid turbo, would they then use stock full nozzles?
    Further more, what would people then recommand for more HP? Bigger IC, or complete 3" exhoust or well?
    Would it be normal to run 1.4 bar peak to 5000 rpm then dropping off to 1 bar at redline?
    If anybody speaking german i can try to write some of the german via PM and they can perhaps translate?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • twoqu
    • Sep 2003
    • 3103
    Originally posted by Jonas_R
    Well,
    /Jonas R.
    Hi,
    The first part 2672 is the compressor side, and the 6.92 is the exhaust turbine, at a guess! You will need to do some more research. Not sure whether that is the Audi Ur MB or Porsche spec. Think there is some compressor maps out there.
    • Jonas_R
      • 3780
      • Country: Denmark
      Originally posted by twoqu
      Hi,
      But definately not a hybrid s2 turbo right?
      /Jonas R.
      • twoqu
        • Sep 2003
        • 3103
        /Jonas R.
        That 2672 is the RS2 compressor wheel. Just need to confirm the turbine. Sounds like all RS2!
        • porkkis
          • 1994
          Easiest would be to unbolt downpipe and maf-turbo hose and measure the inducer and exducer diameters.
          If it's a bit like MTM used to have (their "small hybrid") then it's not a RS2 unit, but slightly smaller.
          I think the MTM hybrid was 48 in (as RS2) and 50 out (54 RS2).
          IIRC MTM promised 315hp max with that turbo. Yours is Hohenester 310hp right?
          EM is probably a stock RS2 one. Injectors may be stock, they probably are.
          IC and exhaust would probably be good to upgrade.
          If you're planning a bigger turbo, sell the old one to me if it's in good shape.
          • Jonas_R
            • 3780
            • Country: Denmark
            What do you mean by in and out? Is this the inner and outer diameter for the inlet on the cold side? not quite sure what it is that you what me to meassure?
            /Jonas R.
            • porkkis
              • 1994
              cold side inlet and hot side outlet ID
              • Jonas_R
                • 3780
                • Country: Denmark
                Any other way? Since this is quite difficult for me just to do
                Could i read something off the turbo and post it here?
                /Jonas R.
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  Well this was the letters i got off the cold side:
                  5326 101 5160
                  Is this a RS2 cold side then or what?
                  /Jonas R.
