RS2 cam timing
  • Pisobiker
    • 1175
    RS2 cam timing
    I've heard rumors about ADU engines needing the cambelt timing to be 1 tooth retarded compared to marks on crank and head cover to run properly. Rumours that say Audi did this and reported the mod on the later model's workshop manuals.....
    Anyone knows something about this?
    Thanks
    Marco
    This is very true, seach the forum for AAH boost problems, which were all related to the RS2 cam timings.
    • twoqu
      • Sep 2003
      • 3103
      Thanks
      Marco
      I think this is it
      • AAH!
        • 497
        • Home: United Kingdom Current: Bhutan
        Originally posted by twoqu
        That is the thread.
        In short: on my RS2 and it seems a number of others, the cam pulley will only line up half a tooth plus or minus of the V mark. Half a tooth ahead of the V mark threw the car into limp home mode with a fault code of "cam sensor fault - short to positive" (even though the cam/hall sensor is not faulty). Half a tooth behind (anti-clock) of the V mark, things worked as they should do.
        Angus
        formally RS2 +
        • twoqu
          • Sep 2003
          • 3103
          Hi!,
          Does this have something to do with the water pump having more teeth or something?
            Hi!,
            That seems to be the general opinion of the forum at present mate.
            • Pisobiker
              • 1175
              Hmm....
              it still sounds strange to me Audi didn't fix the fact marks don't line up. I mean it doesnt't sound..... "German"
              If the problem was the ADU water pump gear being smaller (what I thought at first) then the timing would have needed to be "advanced" half a tooth....
              Do at least the two internal camshaft gear's "O" line up with the crank pulley marks?
              • AAH!
                • 497
                Hi!,
                IIRC the water pump pulley is smaller on the RS2 and the sensor window on the cam pulley is slightly smaller and in a different postion than on the S2.
                I can understand why the water pump pulley is smaller,(so as to pump more water) but not why the cam pulley sensor window is different.
                formally RS2 +
                • mastermind
                  • Jan 2005
                  • 244
                  • Country: South Africa
                  Originally posted by AAH!
                  That is the thread.
                  Angus
                  This was the case with my RS2Avant, however I still have some boost problems on this car.
                  The Red Baron
                  (R)S2 spec, 034 GT3071
                  Wagner Short Intake and Intercooler
                  Whiteline, Custom Shocks with external reservoirs
                  8pot calipers with A8 discs
                  Vems
                    This is an odd one - I've never seen it documented in all the Audi manuals that I have. Maybe there was a separate specific bulletin that covers it...
                    Paul
                    • jade
                      • Jan 2005
                      • 1811
                      Hi i would like any info anyone has because i am about to change my belt tomorrow
                      and my car has been down on power since i got it , and still have not tracked down
                      the problem
                      Cheers Jade
                      RS 2 580HP
                      • Pisobiker
                        • 1175
                        Jade, what seems clear so far is while fitting the new belt in, given you have the mark on the crankshaft pulley aligned, you shouldn't be able to have the mark on the camshaft gear perfectly matching the V mark on the valvetrain cover.
                        In this case you have to fit the cam pulley so that its mark stay 2-3 mm left compared to the V mark on the valvetrain cover.
                        Marco
                        • jade
                          • Jan 2005
                          • 1811
                          Thanks Marco i will take special note when i take her a part to see how it is set now
                          and will follow you instructions
                          Regards Jade
                          RS 2 580HP
                          • jade
                            • Jan 2005
                            • 1811
                            Well my tomorrow turn in to a mouth , But i have now taken the car a part
                            Cambelts been changed , i think but not tensioner or water pumb
                            When i am faceing the car , looking at the cam mark on pully it is to the right of the mark on the cam cover , that is with the marks lined up on fly wheel & crank pully
                            AS i understand from Marco post it should be one thooth back so the cam pully mark is on the left side , is this correct ????
                            Thanks Jade
                            RS 2 580HP
                            • porkkis
                              • 1994
                              Yes
                              And what comes to the narrower hall plate gap I guess they want the timing to be more accurately set on the RS2. I guess..
                              The whole pulley mark issue is a bit strange as the pulley is unique for the ADU as the water pump is. This should mean that the smaller pump gear would not cause this. As Marco said the whole thing does not sound very "german".
