hi just found this site i have coupe 20v turbo with bad holding back problems wen tryin to accelerate hard or put foot down it just doesnt rev then pops throws out bit of black wreak anyone ever had this the engine is standard the now also wot fuse is it 2 clear the ecu and is there a diagnostic plug on this car thanx
20v turbo holding back
Sounds for me like a boost leakOriginally posted by pearlys2hi just found this site i have coupe 20v turbo with bad holding back problems wen tryin to accelerate hard or put foot down it just doesnt rev then pops throws out bit of black wreak anyone ever had this the engine is standard the now also wot fuse is it 2 clear the ecu and is there a diagnostic plug on this car thanx
. Try to search this forum for these two words.
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.com -
If you have a violent missfire like throw you thru the windshield, you have a boost leak or a MAF problem, that is called overboost protection, if you have a lighter missfire, could be ignition problem as well.S2 Limo sold !!!
M5 E34 with some mods in the garage
sorry, but much happeir now !Comment
am gona try the blink codes aswell to see if i can find anything anyone no a good way of testing the MAF is there set resistance through it or something to check it also how do i find out if i have a 3b or aby engine or where the codes are thanxComment
Disconnect the battery, check www.s2central.net it's got all the relevant details regarding codes and reseting.Originally posted by pearlys2something else does anyone know what fuse i pull to reset the ecu of fault codes if i manage to get it fixed sooner than later thanxComment
Pull the 2 fuses which are joined together with 'motor' marked on them for 2 mins.Originally posted by pearlys2something else does anyone know what fuse i pull to reset the ecu of fault codes if i manage to get it fixed sooner than later thanxComment
had the car over for another diagnostic didnt really come up with much i didnt know,possible air flow meter but ive to try the coolant temp sensor and on back of the cylinder head at the master cylinder side theres a temp sensor there aswell is this the sensor just for the ecu its a white clip 2 wire,also under the inlet manifold my coolant temp sensor is brown with 4 wires on a 3b just makin sure as there is a sensor with two spades next to it thanx againComment
It sounds like the common boost leak problem, the temp sender will just give low boost on a 3b. You need to pressure test the intake system, search the forum for this. Loads of info on it. If the cut out is that violent then it "probably" isnt a misfire as such. Does the car feel very slow too? and heavy on fuel??sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
